34 Silverton C Problems
thehopper
I am thinking of buying a 34' Silverton convertible, 1985-1989 model. What problems should I be looking for, w/ the exception of a large fuel bill?
Your surveyor/mechanical inspector should find most issues. SOme particular issues to look for are;
1. Shore power recepticles - check prongs for darkening
2. side panels in cockpit near door - check for water rot
3. read exterior salon panels in cockpit - check for water rot
4. front windshield - check for water leakage
Other 34C owners may have more issues to list but make sure you get a reputable surveyor and mechanical inspector.
Models actually go;
1980 to 1983
1984 to 1988
1989 to 1990
I assume you are looking at 1984 to 1988
I have an 88' 34C. I consider it to be a good family cruiser for the money. I crusie at 17 to 19 kts rb2@gr5t 3600rpm. Fuel burn should be around 30+ GPH with 350cid / 270 hp crusader engines. These engines are reliable, although in rough condisions work hard. Engine access and space to work is excellent. As far as being seaworthy, anythng more than 4' waves is going to be a rough ride.
I agree with "silverton 34" comments a few addational are
- water heaters were recalled, if original you may recieve a free replacement
-came with metal mufflers, must upgrade to fiberglass
-wet deck cores in foredeck, gunnels and bridge deck
-fuel tanks. I have had no issues with my tanks, however some (as observed on another forum) have. The tanks are elevated off the bildge and sit on top of the stringers in the cockpit (two 125gal) and thus are out of the wet zone. If the tanks need to be replaced the deck will need to be cut out and then reglassed in.
Overall, like I said a good boat for the money. We use ours as a weekend condo and take a bay trip about once weekend with an occasional overnight tie up. Get a suvey from a REPUTABLE surveyor.
This topic should be posted on the Silverton Forum, If someone could place it there that would be great.
Bob,
Les, set up "boat specific" forums a few months back.
I only mention this, because you may get more responces there.
I have an '84 model. I agree with the prior posts. A nice family boat with a good reputation.
The hull (below the rubrail) is solid FRP and not subject to rot- but all penetrations still need to be checked for integrity. Anywhere from the rubrail above needs to be carefully checked for water intrusion. My surveyor said because of the wood coring used in manufacture and their age, ALL these boats will have some intrusion. Rail stanchion bases and hatches are always suspect. Look for water stains on the interior surfaces around these areas. Moisture readings below 17% should not be a concern. Higher readings mean the coring is wet and needs attention. The surveyor can tell if the coring has started to rot. If that's the case then repairs can be difficult and expensive. As far as the gas tanks, they did a survey on the SOC site and it was determined that these Silvertons are no more prone to failure or leakage than any other brand of similar age. My boat still has the originals but I DID install a new fume detector just to be safe.
Above all, get a proper survey performed and be present when it's done. It's important.
