Originally posted by foggysail
Originally posted by Starry Night
Alk,
I would not recommend using outdoor Sunbrella canvas for your interior cushions. This is a canvas base material and not what I consider furniture grade material. It is also very stiff and not soft. If you plan on using fabric use Sunbrella furniture fabric or marine grade furniture fabric. You need to remember that you want fabric that will repel mold and mildew. There is alot out there however it is not cheap. Ultraleather is expensive, but I think it is the best when not using fabric. Also I would recommend using new foam as well.
When it comes to sewing machines, you need to remember that most home sewing machines cannot handle size 69, 92, or 138 thread as well as handle a heavier needle when going through multiple pieces of fabric.
I started sewing with my old metal singer from my parents, 1950's. It was ok for some light work, but it could not cut the mustard. I purchased an industrial Juki in 2007. That's were it started.
Bob-- Is your machine a DNU-1541S???? If so, I purchased the same machine about 3 years ago. THAT IS ONE WORKING DOG!!! Good dog that is. I did replace the motor with a servo motor for better speed control. Some guys are good at using the original motor but.... I also junked the desk lamp that came with it, replaced it with a 2 tube fluorescent that has an adjustable arm.
You did a fine job with your project.
I replaced and extended the canvas (Sunbrella)on my 40' Silverton Aft Cabin. Did eveything including the enclosing the rear deck area. Rebuilt the dinette cushions with new foam and covers and the list just seems to go on and on.
A friend who is a cabinet maker has the same boat as I including the hard top from Atlantic Towers. His wife was soooo upset at how great my canvas work was that she forced him into having me make the same for his boat. We agreed on a swap, he installed all new Corian counters in my kitchen plus two new cabinets for my the canvas work.
I do give you credit for attempting your project. I had zero sewing experience prior to starting mine but the stuff is not brain surgery.
GOOD JOB!
Foggy
EDIT: Yes, you have the same machine. I did not completely read the thread before posting, even have the serrvo motor!
