Bad Idea?
fountain27
When I retire I plan to live aboard. (BTW I still have way too many years to count). I want to buy a 46' diesel duck with about 150 hp diesel naturally aspirated.
My mechanical skills are fair and I was considering buying an old low HP diesel to rebuild and learn? Is this a bad idea? If no, any recommendations?
nothing wrong with learning and those low tech diesels can survive most attempts to fix them. Any boat will be a teacher but why an industrial type when so many low power "trawler" types are available and when your are done it will be something attractive.
If you have never rebuilt and engine, start with something that is cheap and easy to do, like a pushmower. Those little Briggs and Straton engines are easy to work on, parts are cheap, and you can either use the mower or sell it when you are through. Once you complete this one, move up to a Chevy or Ford V-8. The Chevy parts are cheaper. Rebuild it and see how this works out for you. If all goes well with both of them, rebuilding a diesel should be no problem. The only part that needs to be set by a pro is the injector pump. I would leave that alone. If you set that wrong, you could over rev the engine and blow it up.....I have seen this happen, it is not pretty.
Hope this helps.
There is nothing wrong with trial and error when parts are cheap, but why not learn what to do first. Look into Mack Boring's two day diesel school. They deal mainly with Yanmars, but i have heard that most of the information is somewhat generic and will work for other brands.
