4roys,
Volvo Penta's corporate HQ's are right down the street from me, and I had a talk with them about the paint issue, and here's the scoop: They recommend that if a boat with Ocean Series Composite Drives is to be kept in the water, that it be treated the same as a boat with aluminum drives for paint purposes. That said, I had mine painted with Interlux's Trilux 33 (Prop & Drive) paint, which does a good job. This is the same product I utilize on all my underwater metals.
On a related note, I had my boat hauled mid-season to change the drives' break-in oil at the suggested interval, and in the process, they power washed my drives. After that, the drives accumulated some barnacles (about 30-40/drive) ..........so I suppose the pressure washing eradicated the remaining protection offered by the previous paint job. That said, I just had the drives re-painted, and next season, I will not allow the drives to be pressure washed during any haul-out unless there is fouling present. If fouling has occurred, it will obviously be time to repaint anyhow. It is my guess though that I will make it through the entire season on one application of Trilux 33. Lesson learned.
In preparation for the re-paint mentioned above, pressure washing easily removed all shell fouling from my drives. This was done right after the boat was pulled out of the water. A word of caution about the pressure washing though...... The Volvo-Penta owner's manual specifically cautions against pressure washing certain areas of their composite drives. Failure to respect this caution can void warrantee, so be careful. I can't remember all the areas to avoid, but they are concentrated around the bellows and hoses in the vicinity of the bellows. Perhaps a quick reference to your manual will bring you up to speed on this constraint.
As for the electrolytic aspects of the Composite drives, I'm still on my original anodes, which still look brand new. I guess the composite material is very beneficial in this regard. As this is my first season with the boat, time will tell.
Best of luck, and hope this helps.
