Bedspread for 1990 Cruiser 3370 Espirit V-berth
crp
Anyone know where I can order a bedspread or get a pattern to make one for the v-berth?
I only see sheets on that site. I've been using regular sheets and a quilt but I want a pattern for the top bedspread so I don't have to tuck in under the mattress.
Make a pattern from heavy plastic or paper and then buy an oversize bed spread and take it to a tailor or seamstress and have them sew it. Using clear plastic is easier than paper as you can see through it. Lay it on your v-berth and use a sharpie marker to outline the perimeter of the v-berth on the plastic. Make sure you add the thickness of the cushions if the bed spread will drape over the sides of the cushions. Just tell the sewer that this is the exact pattern and they have to add for seam allowances. You may also be able to get a canvas shop to pattern it for you and sew it over the winter as they look for work during the winter.
