Bennett says it will be March 2008. Not sure why the hold. The unit works great as advertised. I have it installed on my boat... top right corner of the photo. Also installed next to the AC3000 is a push button that retracts the tabs after I shut down the boat. Hit that the same time I raise the outdrive when putting her back on the trailer...
I have never been able to get my AC2000 to work with my factory Bennett setup on my Chaparral so it sits in the dash covering a hole. I figure it's a wiring issue with the factory trim switches. I normally don't give up, but in this case I did.
I will say Bennett service was great with me replacing miscellaneous parts even after I had probably shorted them.
