Bilge Pumps
jjones
I have a 26' CC which sits fairly high on the trailer as it goes down the road. Yesterday I noticed my bilge pump kicked on while I was stopped at a light. The force was great enough and the height of the flow tall enough that I think if I had been in the left lane it would have hit a vehicle in the right lane at window height. And if they had their window down they would have gotten flooded.
My bilge pumps are wired so they come on automatically even if switched off manually on the console. I like that but I think in the future when I'm trailering the boat I will pull the fuse for the bilge pumps just in case.
I had never noticed that before and I'm certainly glad I did before I pulled up alongside a new Corvette convertable or some other expensive vehicle and flooded it.
I also have noticed that the hoses connected to the pumps do not have clamps on them. They are a type of hard plastic hoses which I'm not sure clamps would do any good on. They have been on there a long long time and there has been no problems with them coming off. But I'm wondering if they are suppossed to have clamps on them or if I should change the hoses out to something that clamps would work on. I don't think the boat would take on much water through the through hull fittings as I believe they are above the water line. But in a storm they might would if a hose came off. And it wouldn't be too good to lose use of the bilge pumps in a storm either.
So I guess my questions are:
1 What type of hose is normally used for bilge pumps?
2 Do you use clamps on them or does it depend on the type of hose?
3 Are most pumps wired to kick on automatically even when the panel switch is turned off?
4 How often do you change out the hoses on the bilge system?
1) Smooth bore neopreme. I avoid the corrugated type as it has high flow resistance.
2) The pumps are normally plumbed with barbed hose fittings, and the hose I use requires clamps. I use clamps.
3) Many are. What you want is to have the pump connected -after- the main battery cutoff switch. That way, when you are on the trailer and the main switch is off, the pumps do not come on.
4) Only when they need replacement. Unlikely to occur.
i agree with Bill...
why dont' you pull the drain plug on the ramp to drain the bilge ? this way, no water... pulling a fuse is not ideal, one you'll forget or loose it....
Agree w/ Radio except for #3.
Pascal hit the target. If you are not draining the boat on the ramp, you are towing a ton of extra weight.
I would just love to watch SOMEONE ELSE get flooded by bilge water from a towed boat. In fact, it would be a Kodak moment!
"The force was great enough and the height of the flow tall enough that I think if I had been in the left lane it would have hit a vehicle in the right lane at window height. And if they had their window down they would have gotten flooded."
THAT would have been AWESOME!!! Would have been the funniest thing I'd heard all week.
I'd pay an admission fee to see your boat "pee" on a convertible. That's hilarious.
Recently due to a small amount of gas leaking from a spin on filter I completely emptied all the water left in my bilge that the pumps didn't pick up. I captured it in five gallon buckets as I drained it to see just how much was in there. It was less than thirty gallons. Water weighs less than 9 lbs per gallon. So if I don't pull the drain plug I'm not really towing that much extra weight.
To me it's more trouble to bother with the drain plug on that big old boat than it is to tow the extra weight. With my luck I'd forget to put the thing back in.
it's not about the weight, it's more about making sure the boat doesn't drown on the trailer. Most small boats get water in the bilge from rain spiling in over hatches, etc... so it's always a good idea to pull the plug when the boat is hauled out.
We have a similar problem except that we keep our boat inside a storage facility. The poor fork lift driver has gotten a lapful of bilge water twice now! (yes we tip him)
We need to leave the pump on auto since for early morning trips they leave the boat in overnight. The driver recommended attaching a piece of leather over the bilge pump fitting to at least deflect the water down if it does turn on when he tilts the boat.
"I would just love to watch SOMEONE ELSE get flooded by bilge water from a towed boat. In fact, it would be a Kodak moment!"
It almost happened to me last week. The boat was just slightly ahead of me in the left lane. 6 feet or so back and I would have gotten a face/lap full of salt water.
My guess is that it's a funny thing to see happen. But not as funny to have happen. Especially if it's dirty bilge water. :-)
A boat pee'ing on a car going down the highway wasn't half as funny as when I jumped off my swim platform (when it was been hauled), walked around the boat and it pee'd on me. I think just the little bounce when I jumped off the platform to the ground triggered the float switch to activate the pump.
bilge water is one of those things where it isn't so bad if it's yours, but if it came from someone else's boat....ewwwww!
mine is wired so that everything is dead when i turn the main switch off, always trailered though.
My pump is wired so that even with battery switch off..she'll run if needed. Not an issue when on trailer with plug pulled...but more for extended time in water where rains and runoff add up...especially when slipped for a length of time.
Drain the bilge to keep it dry in there. No water or moisture equals no corrosion.
I keep the pumps on auto when it's parked at the house. The boat is a big deep vee center console and if a little water collects the pump doesn't pick up it doesn't get anywhere close to being high enough to get to anything, not even a fourth of an inch deep. I always wash down the boat, deck, trailer, everything after the salt water and run enough clean water through the bilge that it is crystal clear down there. We use the boat every weekend. I guess I would pull the plug when the boat will be sitting for a couple of months or so.
But I believe I'm going to go through and check all the hoses and be sure they can't come off in rough water.
Flooding a car at a light would only be funny if it were someone elses boat and car. In fact, it sounds like something that could be set up and videod to win that funniest video show. Let me get everything I need here...
Slightly off-center but along the lines of peeing bilge pumps...
I used to travel this route to work that was also being used at the time by many concrete trucks because of local construction...creating quite a pinch-point for the highway on-ramp. You just learned to deal with the delay.
One day, this really uptight, obnoxious, "me-first" was right ahead of me, but behind one of the concrete trucks and was laying on his horn and getting in and out of his car to see what the hell could be causing this most heinous delay.
The driver of the concrete truck also had obviously been watching this joker and without further adieu, exited his cab...walked to the back of the truck...grabbed the washdown hose and proceeded to throughly drench this jerks car. A washdown hose on a concrete truck is chock-full of sand and residual portland cement...so this guy's car turned a lovely shade of opaque tan! We didn't see too much of Mr. Impatient afterwards...of course, you really couldn't see through the glass.
Because my boat was dry-stacked stored, I actually had something a bit different: The bilge pumps were on their own master switch. This allowed shutting off all items, except the pumps when slipped, but allowed me to disable the pump (, incl th auto switch ) when being stacked.
Several boats had issues when the auto switch got tripped and stuck due to forklift movement. By shutting them down using their own switch, I avoided the dead battery/pump/melted fire hazard risk...
MSibley I have a similar one. As a kid working for a tree surgeon. Going down a road with a full load of chips....Mercedes behind us couldn't believe we were just going the speed limit or a bit below on a back road where everybody speeds. Come to a stop sign...boss lifts the dump a bit....woman on the horn with no mercy....popped the clutch...somebody was cleaning a bunch of woodchips off the hood.
Darn I would have hoped she was driving a convertible....
