Boarding Steps?
AustinPaul
I snagged a really nice slip in a real nice marina. We'll be in a very well protected cove (things can get a little rough at our current slip) and we'll have an unobstructed view of the cove and sunsets--just as long as we dock the new boat bow-in. We're used to boarding via the swim platform when docked stern-in.
Anyway, from where do you like to get your boarding steps? I haven't had a chance to check BoatFix yet. Any particular ones you like more than another? I would guess that we'll need 2-3 step model.
Paul
Todd or Tatlor Made. The Taylor steps have a hole in the back for storage underneath. I cut a hole in the back of my Todd steps and it works just fine.
Great-- thanks. I agree about the 'free' storage too.
Paul
A few treated 2 x 4's, Trek for the treads and some SS screws give a very nice set of boarding steps. You can also make them of plywood, painted with storage if you wish. If you use plywood, 2 x 2's work fine for internal bracing and tread support,
Hi Paul,
I made our own steps to suit our dock.. size and dimension etc.. I used pine to keep the weight light.. I used drywall screws to put it together.. and it is cross braced inside to keep it strong.. was a pretty simple concept to achieve the height. I built it in 2002.. I lagged it down to the wood docks and take it home each winter.. we're still using it at our current dock, but since the docks are fancy plastic decking, I just leave it sit on the dock. It worked out great for us with the dogs..
Originally posted by DogDaze
Hi Paul,
Thanks all!
Hi Joe! Those steps look really nice. It's a big plus to have the bigger 'landing' on the top as you have done. I just wish I were handier with woodworking. :-(
Paul
I made mine too. Used Home Depot precut risers and the handy grooved steps they sell. The Depot precut the treads to 2 feet. An 8 foot treated tread [again HD sells the tread pre grooved for traction] will give you the 3 treads and a cross support. I pre drilled and used SS screws. The whole thing was $50 and took less than an hour. I did them 2 years ago when I had no tools at the boat and needed a quick fix tor a "dock bow in" situation just like yours. Some day I'll epoxy them when the mood hits but I've managed to avoid it so far. You need a cordless drill to do it.
Precut risers-- of course! Now that sounds really good. I'll look into that. Thanks Charlie.
Paul
Hi Paul,
I've seen the precut risers too.. they work out nice as well.
If you look at the pic of mine, it is the same board height for each step, just shortened for the length of the step. I laid them out and they have another board on each end on the back side that holds them together. The back is open other than for the cross brace - so it's nice that we can put stuff under if we want. I tend to throw the recyclables/empties under there until we leave for the weekend.. keeps them from blowing off the dock and out of the way.
Stained them with Sherwin Williams Cuprinol and then added the Non-Skid that I picked up at West Marine on sale at the Dollar Table.. goes on light blue, dries black.. I need to redo them this winter.. thinking of painting them to match our vinyl docks... :)
Hi Paul,
Nice Joe. I would like to have them with a nice extra long 'landing' on the top. Our doggie is older and heavy. Naturally, we have to consider what will work for him too! :-)
Thanks- Paul
Hi Paul,
Yes, the dogs.. thus our step and the landing at the top... could easily make one longer if desired.
I have the step at home for the winter, should you like to build one, I can offer the measurements we used for ours.. I did it such that it only takes up 1/2 the width of our dock.. so as to not exceed the width for our dock neighbor.. Ours step has seen a lot of use, but works well with the dogs and people too.
At the time I built it, I didn't have my table saw.. so I used a hand held circular saw.. it really didn't take too long and the cost was minimal.
Another tip is that we have a rubber backed throw rug that we drape over the side of the boat onto the step.. it really helps with the dogs in that it closes the gap so to speak.. I usually keep one foot on it while getting the dogs on/off. When not on the step, we keep the run in on the floor in the cockpit or we use it for wall to wall carpet in the dink.. for us, it’s all about the dogs.. well, and 1 cat.
Hi Paul,
Hi Joe-- right on the money. I see our boy looking down at the lake when he's moving from dock to boat. If it gets too large a space, he won't go. On steps, I know he'll be even more squirrely. I have a rubber-backed bathroom runner (about 4' long) that we could run from the top step, to down into the cockpit. I agree with you, if he can't see the water inbetween, and can get a good grip, he will be very comfortable. I reckon it'll be good for us people folk too!
Paul
Hi Paul,
Nice Pup... :) It's like anything else, once he gets used to it he'll be fine. Does he like the water? Our girls don't like getting wet.. kind of odd.. well, the OES likes to play when I have the hose out to wash the boat.. but otherwise, they're not swimmers like so many black labs are.
