I need the Mercruiser experts to give me some guidance. I just bought a 1988 Glassport 165RX with the 3.0 Mercruiser (Alpha one Gen one) on a galvanized Shore Lander trailer. Boat was last on the water in 2006 and winterized professionally in Maine. It has not been started since then.
The floor has some dry rotting and all vinyl and seats will have to be replaced if I want to restore it. The hull is in decent condition. Of course none of that really matters unless the motor and drive are good.
Here's the good:
Trailer pulled home over an hour with no issues. Hubs are cool. Tires are good and lights even work.
Shift/throttle cable and linkages all seem good as well as steering.
Outdrive locked in solid as a rock both ways when shifted forward and reverse and spun freely with no noise or resistance when in neutral.
Outside of some minor rust and a few wires that a mouse got ahold of, the motor looked good and the oil looked perfect.
Here's the part I need lots of wisdom on:
I didn't try to turn the motor over with it having set almost 2 decades and I want to do things right to have the best chance of this thing running without a rebuild being needed.
So, please tell me exactly what steps you would take prior to trying to start the motor to attempt to avoid any issues. Please include the order you would do those steps in and what suggestions you have for the outdrive as well.
Here's my goal with the boat:
Get it running first. Then make sure it floats and doesn't have any major issues with the hull that I didn't notice. Then restore the interior and try flip it for a decent profit if all goes well.
I only gave $500 for it. So I figure the outdrive and trailer are worth way more than that if the motor is shot for some reason. Hoping I can have less than $2500 total in it (doing all the work myself) and be able to sell it around $4,000 - 5,000. Figure its a great opportunity for me to learn more on the Mercruisers and get back into working on boats again without much risk.
Here's the good:
