It's messy but not that hard. I put a big tarp down under the boat and sand it lightly with #60 sandpaper to remove anything loose. Like me, you are in a fresh water like so don't get too crazy with the sandpaper, if the paint flakes off in a spot under the waterline it doesn't matter. I use that blue painters masking tape. I use multiseason ablative paint and put it on with a roller and a brush for the hard to reach spots. Being in freshwater, I have had good luck with the inexpensive ($100 per gallon) ablative paint you find on the internet. You need a dust mask when you sand and plan on throwing away all of your clothing, roller, brush etc. when done. Bring mineral spirits to clean up with.
