Chart depths
drfeno
I was just curious if anyone knew how the depths on the charts are taken. I mean are they at low or high tide, or some kind of average? This scarcely matters in 100 feet of water, but it's more important in 6 or 7. Not that I want to push the envelope and run aground, I'm just curious.
The chart datum should be on the chart. In most cases it's "mean low water" (tide) or "mean lower low water". So in theory the water depth will USUALLY be more than is charted.
Unfortunately in many areas the last survey was 10-20 years ago (costs $$$) and things have changed since then. I watch the tides every time I leave the dock (Inches make a difference here) and I still run aground often enough to keep the barnacles knocked off the keel.
"if anyone knew how the depths on the charts are taken"
Yes.
How they are taken is irrelevant, as the data gets "normalized". What you see printed on the chart is usually ( read the notes on the chart you are using! ) MLLW, Mean Lower Low Water, which is defined as, " The average height of the lower low waters over a 19-year period. For shorter periods of observation, corrections are applied to eliminate known variations and reduce the result to the equivalent of a mean 19-year value.".
In short, it is the depth during what is normally considered to the low tide during seasonal low tide.
That said, check the dates of the soundings on your chart. It is likely that the data for the "shallows" you are interested in are old. Really old. I mean, older than your daddy. And those depths were recorded using a lead line, at a position determined with a sextant or other similar device. ie: Don't bet on it.
Those are average depths at "mean low water." In other words, an average low tide. Tide highs/lows may vary depending on a number of factors (moon, wind, storm surges, etc). The important thing to remember is that most charts haven't been updated in years. Look at the date in the compass rose on the chart, and that will give you an idea of how current the information is. If you have concerns about an area you will be boating in, it's best to talk to experienced local boaters.
Joe, the date on the Rose is a "currency date" but it does not date the soundings. Many ( all? ) charts have a data panel that will indicate the date and often source of the soundings for the various areas of the chart. As an example see chart 11363. The panel is located on the left, about 1/3rd the way down from the top.
