COOLING SYSTEM DIAGRAMS
George Van Parys
V8 CLOSED COOLING SYSTEM
Basic V8 cooling system routing, belt driven sea water pump. Note stainless plate separating anti-freeze and sea water in the exhaust manifold.
V8 COOLING SYSTEM
Basic V8 style cooling system with a belt driven sea water pump. Note the water flows from the bottom of the exhaust manifold and exits the rear of the upper riser. This flow chart should suffice, even if your unit uses a sterndrive mounted seawater pump. Cooling flow will be very similar.
