Cutting hole in dash
Gregory S
Well-known member
I need to cut a hole in my dash for a new gauge. My dash has an alluminum cover. Can I use a holesaw? THe alluminum is probably i/8" thick over fiberglass. Thanks.
Greg, you can use a hole saw...just make sure it is sharp and that your mandrel is long enough to hold the saw in place.
Thanks Ram. Are there different hole saws for metal as opposed to wood etc?
Yes. But a wood one should work just fine for thin aluminum over fiberglass.
