- Nov 30, 2006
- 24397
- 230
I am considering options for dinghy davit. I like the Hurley system but it would make my LOA a bit tight for my slip. I was also looking at the weaver and st. Croix models. I noticed on the St. Croix sight that they show the tip up model with the motor still attached (attached while it is tilted up). But they also have an option motor tilt accessory for "salt water applications". They don't explain why the motor tilt is required for salt water and I'm not following why it would be necessary. I have a 2 cycle motor. Does anyone use one of these and keep the motor on the dinghy while tilted up? I would be hesistant that the motor would work loose and fall off. Also, do I need the motor tilt option if I have a 2 cycle motor and boat in brackish water (Chesapeake bay)?
Dan
Dan
