justgotaboat
- Jun 18, 2009
- 31427
- 159
I just got over 500 feet of 3/8s double braided nylon line from work and had a few questions. I have a '01 sea ray 245 weekender and was thinking of making up dock lines and anchor lines with it.
1. I have heard that "conventional wisdom" states 1/8" line per 9' of boat. Is that a good rule of thumb? (I do have some heavier lines that could be used in bad weather)
2. Would this make a good anchor line? I have heard different things about wanting some stretch and am not sure.
3. I was thinking of using 300 feet of it with 25-30 feet of 1/4" or 5/16" chain that I already have to make a new anchor setup. I have plenty more chain (all in one piece that I will cut to length) and all the line to use (whatever is left will probably be made into dock lines of variety of lengths). Should I use more chain or line? The boat is still new to us, so I cannot say what conditions we usually anchor in and the anchor will have to haul it up by hand.
3. With regards to splicing it, I know I need to get a set of fids (or phids?) Is there something I should look for that makes a better, easier to use, more durable set, over a cheap set? Or is it one of those things where a cheap set works just as good as an expensive set.
4. Any recommended books or videos on how to splice it? Any tips or tricks for splicing? I have found some decent videos (as far as I can tell) on youtube that show how to do it, but advice from someone who has done it is always appreciated. Things to look for, avoid, do, don't do.
Thanks for the help!
