Engine for a Dink
ALKA2710
Just bought the Mercury 340 Hypalon Airdeck its 11'2" up to 15hp. Not sure if I should get a 9.9 or the 15 hp. Is there that big of a difference in the 2. Might instinct is to buy the 15hp. Also Yamaha or Mercury. Found a nice used Yamaha that I am looking at. Any thoughts positive or negative would be appreciated.
Al
merc and yami are the same motors built by yami
9.9 to 15hp is not that much diffence
I have a Zodiac 310 with a 15hp Evinrude 2 stroke. With the Evinrudes and I suspect the same is true for Yamaha, the only difference between the 9 and 15 is the carb and 500 rpm.
The boat is a scream with a 15. Wide open with just 1 aboard, it's quite twitchy but scary fast. It will plane out with 3 grown men aboard if they work together like a bobsled team.
Kev
Al,
It depends on how often you will lift your motor on and off the dink. For that reason, I bought a 5hp Mercury for when I want to take the dink on my boat. I have a 15hp for playing around at the marina and on the river.
I think I will go with the 15 hp. Lifitng it on and off is not a problem. This is the first time that I heard that Yamaha makes merc. Is that like Ford and Mercury being the same. Also Craig let me know what boat you get. I orderd mine on Monday in the am and it was delivered on Tuesday night. The 340 is cheaper than the 310 and it is also made of Hypalon with a 10 year warranty as opposed to PVC and a 5 year warranty. I will just struggle with the extra foot.
Al
Actually the 15 hp is a 9.9 bored out more. Should be very close in weight. If the dink can handle it, go for the 15. Never heard of TOO much power...
You will be much more satisfied with the 15 hp. It has the speed when you need it and you are not penalized if you don't want to go running willy-nilly about the marina at high speeds.
I don't know what you think about 4 vs 2 strokes but my 2 cents is that the 4 runs better but when it gets a problem it is much harder to diagnose. My 15 Yamaha still stalls upon initial acceleraton even tho I have used every suggestion on how to fix it. Back to the shop, I guess.
the 4-strokes are generally heavier.
i would go with the 15hp. i made the mistake of buying to small of a motor and went back out to buy a bigger motor.
I did the opposite, I bought the max rated for my dink, although it does cruise nice with it, it is too heavy to lift on and off the boat for quick runs into shore. So I went out and bought a little single cylinder 5hp that now lives on the boat.
I just bought a Avon RIB 330 and I was planning to use my 8 hp Tohatsu with it. However, it will not plan the boat with two people. It flys with 1 person. The dinghy is rated for a 4 stroke 25 hp. I'm gonna save my pennies for another (larger) motor in the future. I have a crane that is rated for 400lbs, so I can handle loading and unloading.
Question: should you prop an outboard like an inboard? So if my 8 hp motor won't make WOT with three people (normal load), should I get a smaller prop (pitch/diameter)?
Good question. That might be something to look into. How do you know if you are hitting wot?
there are rotating motor mounts that will allow you to keep the motor attached to the dink, even when the dink is flipped up on the swim platform while held on with davits. a bit pricy, but no hassles of loading and unloading the motor.
Well, it is clearly not turning as fast with three people than with one person. Without a tach, it is kind of hard to figure out how much to change the prop. Recently I had 4 people in the dinghy and after loading it on the deck, it leaked some oil out of the exhaust. This made me think that it was not completely burning it's fuel/oil. I guess that I could try to put a photo tach on it.
