I spent a couple hours on Saturday engineering a shifter for my 15 hp johnson. I want to be to sit on the seat in the middle of the boat and be able to shift. The johnson has the shifter on the starboard side of the engine. i also need it to be easily removed and installed so it is not in the way when there are more aboard.
I have already built the tiller/throtle extention out of pvc pipe.
I tried using an auto choke cable but that has too much flex so I ended up building it out of 1/2" PVC pipe. it runs alongside the throttle then across the front of the engine and then back to the shift lever. It IS FUNCTIONAL......BUT it is not very pleasing to the eye.
So who has a better way to do this. I was thinking about a selanoid that would push and pull the shifter but it would need three positions and powere of some sort.
