EPIRB registration
Moderator
speaking of EPIRBs, check your registration!
i sent one by mail last year and when i looked it up on line it wasnt' found. Only took a few minutes to register it again.
so check yours, make sure the info is accurate.
https://beaconregistration.noaa.gov/rgdb/
I would add to that to make sure that your battery replacement is within the manufacturers' required time period.....and if it has a test function to also follow that procedure.......
And if you use an inflatable PFD onboard, be sure to thoroughly inspect it every season and replace the rearming kit in a timely manner.
Several safety things to keep in mind as we prepare for the coming boating season.
Good call! Keep those registrations current - the information REALLY does matter! Take a look at the sticker that you should have been mailed and should have placed on the beacon after registration - it should have a date on it. If it isn't current, or any information has changed (such as usual area of operation, contact names, contact phone numbers, ownership, et cetera), take the few minutes to update it. It's online now, so you could probably complete the process in less time than it took me to type this reply!
while we're on these safety topics, what does the USCG recommend when it comes to marking PFDs with the boat name? I've never heard anything on that, never really worried about it until i saw a report that they found a couple of PFDs during the search in the gulf earlier. my first thought was, how do they know it has anythign to do with this case.
seems to me that marking PFDs could be useful.
I was told by the USCG Aux. guy who did an inspection that not only should all PFDs be marked with the vessel name, they should also be removed from their plastic bags....
