Fender storage question
Chriznat20
I have a 25' Four Winns and am SO sick of storing the fenders (8"x26" IIRC) underneath the rear seating. Every time I open the engine hatch, I have to move them and they are annoying.
The other day I saw a boat float by that had their fenders "hung" off their rails, horizontally not vertically, and it wasnt the stainless steel racks Im used to seeing that hold them up and down. There were 2 apparatus on each end of the fender that held it about 3" from the rail, in between rail posts.
Is anybody familiar with these? Where can I find them? Ive been googling for hours, it seems, with no luck....
Never seen them but I was thinking of building some with parts from homedepotlowes. If your fenders are innies (the line passes through the center) you could use a threaded steel rod covered in PVC and some 90* connectors and go up through the rail with stainless bolts. If the fenders are outies (a line attaches to each end) you could use stainless bolts drilled right through the rail and some wing nuts with fender washers.
I did not want to drill the rails so I went with the fender baskets.
There are clips that you can buy on BoatFix that are made for handling fenders on the rail or the wire running between the uprights,
call me old fashioned, but i really prefer to have my fenders stored while underway. they block the vision if they are on deck. my largest fenders live in the aft head while underway. the small ones live in the lazeret and forward deck lockers. the little ones don't see much action. everyone makes fun of the large ones, right up until they want to raft and then are glad there is some meat between the boats. a friend pick up four of the larger inflatable fenders at the last boat show. they are somewhat inconvienent having to inflate them, but no one minds when rafting up to them.
I hang mine horizontal on the rails. No need for racks. My fenders are the type with the line through the center. Just tie each end of the line with a neat and secure knot that is easy to untie and they hang there as neatly as any rack will allow. I simply wrap the extra line around the rail to take up any extra length it has.
I agree with vic. On my boat I removed the cabin table and left the v-birth filled in. I store my fenders under the filled in area which is hidden from view by the overhanging comforter.
I have a couple of this kind for rafting or stern in docking. Can the kadi work for these too?
On my 26' Crownline, I took that idea of the Fender Caddy - and wound up hanging my fenders from the bow rail horizontally. I had the end closest to the fender tied to the rail with a Clove Hitch. Then I make 3-4 spiral wraps down the rail towards the other end of the fender, then tie that end off with another clove hitch, with an extra 1/2 hitch for good measure. It worked great and no matter WHO was helping with the boat, I knew that when they went to set my fenders that the fenders weren't going to go into the water because my "helper" couldn't tie a knot.
Here's a photo of my last boat and how I had them set up. They are a little loose in this photo.
Originally posted by Chriznat20
THIS is what I was talking about!
http://www.fender-kadi.com/fender.html
I just ordered 4 sets (total of 8 brackets). Awesome idea, IMO.
How long before you get tired of tying and untying lines each time you store/take out the fenders?
Not sure I see the convenience factor here.
No harder to untie a clove hitch than it is to use the fender hangers. Mine is hung exactly where they are used and a clove is easily adjusted to the length needed. However if you want to spend the money for the brackets thats ok as well!
Same here as Larry B stated. My bow fenders are right were they are used - ready to go! I seriously looked at the Fender Caddies but thought I would try it with the fender lines first. Needless to say, I never saw a need to buy them once I set my fenders up like in the above photo. And I'm a "gadget guy" so I like to buy things for the "cool / wow factor".
Rommer, another way to look at it is if you got the Caddies, you still have to tie up/off your fender lines so they aren't in the water or slapping up against the boat. ;)
IMHO I hate the look of fenders that are not properly stored. Racks make the most sense but if you do not want to pay for them just continue storing them whereever you can. It makes your boat look alot better.
Van
