I'm thinking of buying a refurbished Nuclear Reactor to use on my boat? It's only $40 Million so I should save a ton of money by not using and Diesel Fuel. The projection is it pays for itself within 3 weekends?
Originally posted by Goat Locker
Ex Navy Nuke here....always wanted to spend a little time on the water around NY. Let me know if you need any help starting it up. You just need to watch for the overlap when it goes from the source range into the intermediate range, when it is critical, and when is the point of adding heat. Simple enough. Problem is where do you discharge the water to when you heat up?
The Goat Locker
2007 Regal 3060
Originally posted by rduhon
I hear the spark plugs for that nuke thingy are quite expensive...
