If its an actual hole, it should be filled first. If its not a structural problem, I would use some polyester resin thickened with milled fibers. Marintex is great stuff, but its an epoxy material and the gel coat, which is polyester based, won't bond well to epoxy. If you can get to the back side of this hole, tape some wax paper over the back side, fill with the thickened polyester, leaving it a bit below the surface to allow for the gel coat. Sand the filled area with 80 grit, clean with acetone, then fill with gelcoat. allow the gel coat to cure for a few hours and then cover it with wax paper, plastic or spray with PVA (If you're using the spectrum stuff, no need for this as it has wax in it. Let it cure overnight, sand with 300, 400, 600, 800, buff with 3m super duty compound, then wax. If you post a pic of the damage, that would be helpful.
