How does an Engine Sync Gauge Work ?
Pilotpak
Does any-one know what data source drives an engine sync gauge (Gas Merc 5l MPI Bravo 3 Sterndrives) ?
i.e. does it use a feed from the tacho's, or is there some kind of pressure sensor somewhere in the transmission / leg.
I'm just curious, because when my sync gauge shows engines sync'd (and it both feels & sounds in sync), the tacho's show a 200 rpm difference.
Wayne
Larson 310
Synch gauges use the same signals as your tachometers. The synch gauge senses and displays any difference in frequency of firing pulses from the two engines. If there are any differences the gauge needle is deflected from zero.
All gauges potentially have calibration corrections, but these typically get larger the farther you are away from zero. In the case of the synch gauge the zero point is the in-synch position. So I would trust your synch gauge more than the absolute reading on your tachometers (especially if the engines sound like they are matched). I'll bet that if you put a calibrated tachometer on your engines you would find the one or both of your instrument panel tachometers are slightly off.
M. Eide
I have a similar condition with twin 1989 5.7L sterndrives. I assure you that in my boat, the sync is nowhere near accurate. When I first purchased the boat, I ran by the sync and one motor used significantly more fuel as well as sounding unbalanced starboard to port. I have replaced the tachs and the sync gauge and have the same condition. At low RPM, the tachs and sync are in agreement. As the RPM increases, the sync gauge becomes more and more off center. At my cruise speed of 3100 RPM, I need to increase the RPM of the starboard motor by about 200 RPM to balance the sync gauge. I have never been able to find anyone that could tell me how to rectify the issue so I run by the tachs and disregard the sync gauge.
Mike the best sync gauge is your ears, if it sounds right that is where I would be. My Sync gauge says they are in sync but my ears and the feel says different.
The faria sync gauge for magnetic diesel pickup has an adjustment to balance the sync gauge. I suspect other gauges do as well. In fact many tachs have an adjustment pot as well. I use a handheld photo tack to check engine speed and then adjust the helm tach to match.
When your on the bridge and the engines are quiet and all you can hear is the wind then the sync gauge is important.
My synch gauge is pretty close to my ear gauge. You can feel and hear the engines come into synch long before the actual gauge comes into play.
I am trying to get used to twins so I bring both engines up to cruise RPM and adjust one (usually the starboard) engine to match the other. The synch gauge is a great tool for gross adjustments, however when the boat settles in, the synch gauge is usually a tad to port.
walterv has it right. You can here when they are in sync. Cover the gages so you can't see them. Set one throttle and leave it alone. Bring the other throttle up and down. As you get near the sync point you will start to hear a thrum thrum thrum. As you get closer these thrum points will become closer together until you reach sync and you get a perfect blend. Now look at your gages.
To expand on old houseboater's "thrum" line:
As they start to get close you will hear "thrum-thrum-thrum-thrum"
As they get closer, you will hear "Thhrumm.....Thrrumm...Thrumm.
Closer yet... Thrruuuummmmmm.......Thruuuummmmmm....Thrummmmm....
What you are striving for is Thruuuuuuummmmmmmmmmmmmmmmmm....
I'm not striving for Thruuuuuuummmmmmmmmmmmmmmmmm....
I'm just striving to make a rich girl happy. Is that so wrong!!
The "thruming"ound is what is known as the beat frequency. Most dual engines produce the same sound-- when the sounds are of slightly different frequency, one hears the difference in the frequency as a sound. The closer the speeds of the engines the loweer the frequency difference. However having both engines at the same speed will optimize power delivered to propelling the vessel only if the props identically couple the engine to the water. In other words make sure your props are matched.
Electric tachs simply indicate an average value of the voltage produced by the ignition input pulses of an engine; the more pulses per second the higher the average voltage--this voltage is proportional to the rpm of the engine which the meter shows. A synchronizer simply compares the tach voltage output of two engines and shows the difference--if the average ignition voltage of the two engines is the same then the voltage difference is zero and the engines are in synch. If the difference is not zero then the engine with the highest rpm is producing the higher voltage and so on.
undertow, re: "I have never been able to find anyone that could tell me how to rectify the issue so I run by the tachs and disregard the sync gauge."
I'd bet your sync gauge is fine and that you need to have prop scan match your props.
