Macerator
A little help my friends. When I go to flip the macerator switch and the breaker pops, what is causing this?
A) Is the macerator plugged up?
B) Is the macerator TOAST?
and can it be rebuilt or just replace it?
Thanks for your help
Need more info. What brand? If its a Jabsco, there is a slotted end on the shaft that can be turned with a screw driver, to free it up. they do get frozen in one spot if not used enough.
I would stay simple first and check for clog. If you have the impeller type you can either try and get a screwdriver to the back of it and turn manually (slot on end of shaft), or reverse the wires and flip switch briefly to try and blow the obstruction back. This was always succesful for me. I never did much care for taking them apart.
If neither way works, then it may be time to remove it to get a better idea as to what is going on.
Just a quick note I had something similar happen on my boat last week. It turns out on my boat a Mainship the Head pump and shower sump are on the same breaker. The shower sump was at fault. I thought I had a bad pump on my head, but after some troubleshooting it turned out to be the shower sump was shorted and the float switch was stuck on. Regards Bill
Taste of Grace ... I just had to remove a little used macerator pump from my boat as it now lives in Lake Lanier and was told by the DNR it must be removed. If you need to replace and are interested in an almost new pump send me an E-mail. These can often be freed up by turning them with a screwdrive as mentioned above, if the clog had not been there too long.
Sorry about that reply there. Pete thanks for the note, I will be up to our boat next weekend to either fix the problem or see what I need to replace. My boat came from lake lanier, the guy I bought it from was keeping it at Aqualand Marina. It is crazy but you can pump out up on the Tennesse river. We do not make habit of doing this, but we got in a pinch last weekend and our holding tank was full. We where not going to be back to our marina for another two days. We managed but it was not fun, talk to you soon.
Taste
I agree with gary... its probably just stuck and not clogged.. Not like theres a rinse cycle to clean out the pump. Stuff just gets nasty and hard... Try and spin the impeller like he said .. that should do the trick...
Originally posted by skolbe
Since when can you legally pump out in a river?
He/she didn't say they were pumping out. The macerator is stuck. Might be a trailerable that they pump out via the macerator at an RV park or in their driveway via an access port to the waste system. Not too common, but not unheard of.
This reply is for those woundering the same thing as our friend SKOLBE. I know it is CRAZY and the only time we have done it is in a emergency need.
All navigable interstate inland waterways— except for a few specifically designated NDZ such as impoundments that are municipal reservoirs—are areas where treated discharge is permitted, making Type I and II MSDs legal to use. In NDZs overboard discharge of any kind is illegal and subject to fine. This means you must have a holding tank. And in some places you may not even be allowed a Y-valve, (common in saltwater regions) between the toilet and holding tank for emergency pump-outs or a macerator to dump the tank. Installing a means of locking the Yvalve in the tank position may or may not satisfy local authorities. The Tenn. river is in this interstate navigable waters.
Taste of Grace
