Man killed while painting bottom
jodon2
http://www.app.com/apps/pbcs.dll/article?AID=/20080502/NEWS/80502016
How many times have I been squeezed up in under my boat thinking, if this boat comes off its blocks it is going to be messy.
Maybe I won't paint the hull this year...
Shel
Myself I use a roller with a small handle on it. No need to get under the boat.
Not smart to get under a boat (or anything) that is only supported by a jack. I just read an article about the danger of lifting antique runabouts by the lifting rings, as years of corrosion etc may have weakened them. Be careful!!
I took my boat of the trailer in my driveway last year to barrier coat and paint it. I made it clear to everyone in my family and my neighbors that they needed to stay away from it. I painted it using a roller with a long rod. To go under 6000 pounds on jack stands was a little extreme for me.
I feel for his family and friends, but please peaple be carefull out there.
MJK
Strainers, transducers .... All under the boat... Just have to be safe.....
We all have squeezed under.....
This be a pic of a past boat I had. Its on a tide grid for bottom paint. When loading the boat you lean it just a hair over so it sets up against the pilings. I use some old life vests between the boat and pilings. When the keel sits down I remove them vests and tie the boat in tite to the pilings. Then ya sit around for the tide ta drop. Once the water clears the hull you have to block the keel. On this grid I use 2x4 s about 8 feet long. I run em along the grids timber so I dont have to get under the boat. I nail em in on both sides. No biggie it locks the boat in place.
I have watched several people load a boat onto that grid over the years. For what ever reason they dont block the keel. I think they just dont know that its part of the process.
Any way back a few years a guy loaded his 36 foot woodie monk tri cabin onto the grid. They see a guy do it and off they go. Well he did not lock the keel into place. I suggested that to him but he knew better. What ever.
Guy was lucky. He had bin playing around getting his painting stuff ready. Went up the ladder to get some more stuff from the boat. At that moment a cleat from the boat pulled out. The timber on the boat it was set into failed ( rotten ). The boat spun just a bit then fell over on the grid. It was fast with no warning. It just fell over.
The tide came back in , the boat floated off. Nope no painting goin on that day.
Later that summer I saw that same boat head out the river mouth with some folks on board. I was on the hook in cowards cove. Well named.
About an hour later the old wood boat came back up into the river. I could tell she was full of water and on her way down. A couple of us managed to convince him to get it on the beach. There I ran my pump over and started to de water her on the incoming tide.
Coast guard was called then marine assist took over.
When she leaned over on the grid a couple of planks on that side took a hit. The fasteners were simply no good and popped in the rough water.
Just sharing cause ya just never know who might be thinking about using a tide grid.
I am not real fond of walking around on my boat when it's on blocks with jack stands. You can feel it move even when it's properly blocked.
When I paint under the boat, I make sure Mrs. Know is at least 20 miles away :)
One job I pay the yard to do, I figure I do everything else myself so I'll gladly pay for that.
I sell automotive and truck jacks and stands for a living, I'm the guy the insurance companies and lawyers call when someone gets hurt or dies. The story stated that a jack was being used to support the boat. I'd be a very rich man if I got a nickel every time I have to explain that a hydraulic jack is not to be used support a load - jacks rarely have catastrophic failures when used correctly. I'm amazed at the people that crawl under an 18 wheeler that is only held up by a hydraulic jack. I have no problem crawling around under my boat that is supported by six blocks and 4 mechanical stands.
I also feel very bad for the family, unfortunately, I see it all too often.
I get nervous when I see people walking around under a boat in the straps. A few years ago, an old wooden headboat was being moved in a local yard when one of the straps broke. Nobody hurt but the keel broke when the boat hit the ground. The CG will not certify a boat with a repaired keel for hauling paying customers. A group of friends bought the boat for nothing and are converting her to a floating vacation cond. Anyway, if a stap breaks while you're under it power washing it, well thats it.
About every two or three months, I end up changing the oil in one car or another. Sometimes it's cold or rainy. Almost every time I think "This won't take long, the jack will hold it up." Fortunately, for 20 years I have always concluded the saved few minutes of skipping the jack stands is outweighed by the family finding me crushed under the car/truck. Thanks for the reinforcement.
Some people learn the hard way. A jack is used to raise something, not support it. I feel comfortable working under a car with jack stands. Buy the proper size! Cinder blocks, although they seem good, are not the best idea. Most people use them the wrong way. Most times you get lucky. In rare cases like this, unlucky means you pay the ultimate price.
This why I block the boat at 4 points on the keel, use half a steel cradle plus 2 boat stands foreward. The boat simply cannot fall. People take chances especially with small boats thinking nothing will happen because they don't weigh much. Once even something as light as a couple thousand pounds starts to slide it is 'Game Over'.
