Mercruiser Sterndrive Oil Capacitys
George Van Parys
MODELS Lube capacity (note: 1)
PRODUCTION
60 18 1/4 fl.oz 541 ml
80-90 22 fl oz. 651 ml
I(2) 8 fl.oz. 237 ml
I(3) 18 fl.oz. 532 ml
IA-IB-IC (note:2) 8 fl.oz. 237 ml
IA-IB-IC (note:3) 23 fl oz. 680 ml
I(120-260)
R-MR-Alpha One 32 fl.oz. 946 ml
Alpha One
Generation Two
(excluding monitor) 39.2 fl.oz 1160 ml
Alpha One
Generation Two
(including monitor A) 64 fl.oz 1892 ml
AlphaOne
Generation Two
monitor B) 76 fl.oz 2247 ml
Brave One
(excluding monitor) 2 U. S Quarts 1.9L
Brave One
(including monitor A) 2.8 U. S. Quarts 2.65L
Brave One
(including monitor B) 3.55 U. S Quarts 3.36L
Brave Two
(excluding monitor) 2.5 U. S quarts 2.4L
Brave Two
(including monitor A) 3.2 U. S. Quarts 3.03L
Brave Two
(including monitor B) 3.95 U. S. Quarts 3.73L
Brave Three
(excluding monitor) 2 U. S. Quarts 1.9L
Brave Three
(including monitor B) 3 U. S. Quarts 2.9L
Blackhawk
(excluding monitor) 1.75 U. S. Quarts 1.66L
Blackhawk
(including monitor B) 2.5 U. S. Quarts 2.61L
II 5.75 U. S. Quarts 4L
II (HP gear-housing) 7 U. S Quarts 6.6L
215E-215H 4 U. S. Quarts 3.8L
IITR-TR 4 U. S. Quarts 3.8L
IITRS-TRS 3 U S. Quarts 2.8L
HIGH PERFORMANCE MODELS
Alpha SS 32 fl. oz 946ml
II SSM 4.5 U. S. Quarts 4.25L
III Clubfoot 5.63 U. S. Quarts 5.32L
II SSM/III-A SSM 9.38 U. S. Quarts 8.9L
IV SSM - V SSM (std.) 6.75 U. S. Quarts 6.39L
IV SSM - V SSM
(1 in. spacer) 7.5 U. S. Quarts 7.10L
IV SSM - V SSM
(2 in. spacer) 8.25 U. S. Quarts 7.80L
Iv SSM -V SSM
(3 in. spacer) 9 u.s. quarts 8.50L
VI SSM (std) 20 U. S. Quarts 19L
VII SSM(std.) 16 U. S. Quarts 15.2L
BORG WARNER TRANSMISSIONS
1:1 2 U. S. Quarts 1.9L
1.5:1 30:1 3 U. S.Quarts 2.8L
V-Drive 41/2 U. S. Quarts 4.25L
5000_1.5:1
(8 deg down angle) 2 1/2 U S. Quarts 2.4L
HURTH TRANSMISSIONS
Hyd. Shift 41/2 U S Quarts 4.0L
V-Drive 5 U S Quarts 4.7L
630A
(8 deg down angle) 4.2 U S. Quarts 4.o L
800AM
(8 deg down angle) 4.4 U. S. Quarts 4.1L
MERCURY MARINE TRANSMISSIONS
All 2 U. S Quart 1.9L
(1) Capacities given are approximate. Proper filling procedure is specified in the Service Manuals and Operation/Maintenance Manuals.
(2) Drive shaft housing.
(3) Gear case housing.
