motors
BIGTHUG
how if any do you tell the difference between a 350 and a 305 besides the inside of the block
Unless it's labeled somewhere on the outside with cubic inch or horsepower they are the exact same motor except for the diameter of the cylinder bore. 305's are rated at 228hp and 350's are rated at 260hp as a rule.
Pop a head...the combustion chamber and valves of a 305 are smaller than 350.:)
Then there's the casting number on the back of the block where the bell housing connects. Port side and below/behind the port head.
