Nitrogen spray can source
dollelliott
I came across an interesting product while cruising varnish sales and cannot "refind" it. It was an aerosol can of nitrogen which can be sprayed into a partially used can of varnish or paint to retard the formation of a "skin" on the surface (displaces oxygen). The nearest I can come to it is "Freeze Away" which is liquid nitrogen to treat warts available at the local drug store. Any ideas where I can find this product?
You can buy direct, or from "fine woodworking supply" stores, two of my favorite: Constantine's ( Ft. Lauderdale ) and Woodworker's Supply. ( NM, WY, NC )
RS won't carry it. ( To my knowledge never have )
Ah! Finally found it with a neighbor's help: you are correct: "BLOXYGEN". Does just what I want it to do: prevents the varnish from developing a membrane. Thanx muchly.
