I plan to mount some old bronze ship lights on top of pressure treated wood. To do so I had 1/4" aluminum sheets fabricated to first mount on the top of the pressure treated posts. The marine lights will be mounted [bolted] to the aluminum plates.
My first inclination was to be sure to use aluminum screws when mounting the aluminum plate to avoid the galvanic action but then I got thinking that the problem may be with the aluminum screw threads and the chemical treated wood. Someone else suggested that I could use regular coated decking screws because the coating would isolate the two metals..
Lastly since the flat surface of the bronze lights will sit on top of the aluminum plate which will be painted does that require a gasket or will the paint be good enough to isolate the metals?
