Pro Polish how much do I need?
I have read that a 22oz can of buff magic does a 40 boat I figured that I would get two cans.
I can't find any info on how much pro polish I need and would like to order soon.
Does Boatfix sell? I was unable to find any cleaners on the site?
Probably need about as much ProPolish as you need Buff Magic ... I am using the same products on my boat and I used a little less that one unit of each ... BTW it did a great jobh!!
Get two Pro Polish and you'll have about 1/2 bottle left.
I found both on boatfix and order 2 of each. My turn to test the speedy delivery. With a little luck I may get to Buff out next weekend.
I just got one buff magic (22 oz)and one pro polish (16 oz) from boatfix. Is that enough for 32 foot boat?
It should be enough to do the entire hull ... not sure about topsides.
I just used 1/2 can of Buff Magic and 1/2 bottle of Pro Polish to do the entire hull of my 34' boat. You should have enough for the topsides too.
Greg,
Had you previously used BM and PP? If yes, do you think one of each would be enough for first timers on a 34 footer?
Erich
Depends if you use the Buff Magic "sparingly" as you should.
I just did a hull on a 41 sea ray and used less than a half can of buff magic, the went over with 3m scotchgard wax, looks great but you have to wash your yellow polish pad cant spur it. boat wash marine.
My foam pads say to clean with a nylon brush while the wool pads call for spurring. I just applied a second coat of Pro Polish to my hull (to the rubrail) and still have about 1/4 bottle left.
I finally started today and so far I used one and 1/4 cans of Buff magic. I still have and 3/4 of one side to do. I needed to clean or replace my pads so I had to stop. I started using the pro-polish and it looks great but not sure how much I will need good thing I ordered too much. I does look good can't wait to finish. My parents are coming up from Florida tomorrow they haven't seen the boat yet and being that they are the reason I'm into boating I want to make a good impression. If the weather would hold out I be in the water be the end of the week but with the rain and yes snow coming looks like it will be more like two weeks. Still about the same time I always go in.
