prop size?
seadoo97
Hello all. I own a 98 Four Winns 4.3 and boat at Lake Powell which is at 3600 feet currently. I am running 14 and a half by 19. Just wondering if this size prop is the correct size and if it is not will it damage my drive trane?
need to know what your expected and actual WOT rpms are with a normal load on board.
Just wanted to know if the prop size is to much for my motor to handle. WOT is 3000 rpm to 3500 rpm just cruisin an water skiing.
What does your engine owner's manual say is the specified WOT RPM range for your engine ( perhaps 4400-4800 or 4600-4800 if 4.3l is the engine size?) , and can you actually obtain close to the middle of that RPM range while running at top speed through the water at Lake Powell? If you can't reach the spec'd RPM you are overloading the engine at least and it will not appreciate that. If WOT is low, a drop in that 19" pitch by every 1" should bring WOT up by ~150-200 RPMs, assuming the same metal and design of prop, & that your present prop is in perfect condition & you are trimming for optimum performance, hull is clean, engine is tuned up, you are using good fuel of octane recommended by engine maker and the Lake is not covered with ice :D.
Piranha (piranha dot com)has a blade replacement program until you dial it in to your WOT Max RPM. I had very good luck with them. No affiliation with the manufacturer of the product.
Thanks for the nfo helps a lot. By the way Lake Powell never freezes up.
Still need to know what rpms you reach at WOT with a normal load. 3000 to 3500 can't be the engines's expected wot .
WOT RPM range on a 4.3 is 4400-4800. If your engine is not turning in that range you need to change the propeller. If you are turning 3000-3500 at WOT, that is not good. I have a 14.25 x 21 aluminum prop that let's the motor turn over 4800rpm, the rev limiter will kick in, my other prop is a 14 x 23 that let's it turn 4400-4600. I've swapped them around, but the boat just runs overall better with the 23p propeller. I don't have an issue with altitude, but I tend to pickup about 200rpm in the winter months when the air is cool vs the heat and humidity of the summer.
