Hi, I want to replace the carpet on our Nordic Tugs. The carpet is glued to the floor with a very tenacious adhesive. Do anyone have a suggestion as to how about removing the carpet.
Al Casanova
Alot of patience and a very sharp scraper. It helps to use a carpet razor blade around the edges first if there are any areas you don't want to remove. What are you replacing the carpet with? It doesn't have to be as "clean" if you are going back with carpet.
Do what I did: accidentally soak cabin floor in 3 inches of water for 3 weeks. Discover water and use shop vac to suck it up. Let water try to evaporate during January. Pull up old carpet before entire boat turns moldy.
Worked for me! After all that water, the carpet came right up.
PS----this really happened to me, but I do NOT recommend this method----good luck!
Me: "SON???? I have a little job for you!"
Son: "It's gonna cost ya dad."
Me: "It always does, and I need it done yesterday... get started."
Son: "Luv ya dad!
Son: "Luv ya dad!
Me too. Then, when are you gonna finish that carpet? I dunno, soon, can I borrow $50?
Then, Dad, I can't get it too come out can you help? Then, Son, where are you?
Wife : He went to his girl friend's house.
Dancer
You must be in the "advanced stages" of child labor... I have at least another 1-2 years of "good work" left before the ladies are more attractive than cash for mine.
