I replaced the caulk around the top of my rub rail last year. Factory had done a real lousy and messy job of installing it in the first place. The rub rail in white on the outside with a stainless section in the middle with screws every 8 inches or so. Well....
The white 3M 4200 caulk is now turning yellow. It has faded so much that it is seriously noticable against the white boat and white plastic on the rub rail.
Did I use the wrong caulk? Should I just use white silicone?
The boat is always covered with a mooring cover and is under a covered dock when not in use.
What's your thoughts.
