Spray Nine
MichaelNJ
Is there any real difference between Marine Spray Nine and regular Spray Nine aside from $12 / gal at Home Depot vs. $22 / gal at a marine store?
Only difference is the label on the bottle. You can call amnufacturer to verify, like i did.
I use their product for everything. Works great.
Well when I use up the gallon I just bought, I'll get it from Home Depot. Even at $22 / gal it's not a bad deal. It is a good product.
Spray Nine is another all around cleaning solution. I used to to use it around the house for all kinds of clean up. Now I used Greased Lightening but Spray Nine is good stuff too.
I believe it is another acid based solution. Works well. Don't get it on fabric or any skin break.
Actually its a strong base, (high pH). It also has germacidal properties. Spray Nine is made by Knight Chemicals in NY, my uncle used to be a distributor for them. Spray Nine is a good bleaching agent, cleans whitewall tires, removes grease, mold, mildew etc. NEVER use it on glass as it will pit glass if allowed to dry , something hdrofluoric acid if memory serves.
I just bought a gallon of "regular" Spray Nine (it really is all the same) today from Lowes for $9.99.
Many years ago I used Spray 9 to clean my shore power cords. It did such a good job that it even cleaned off some of the yellow.
But it did get some dirt that nothin' else would touch.
Chris, you contradicted yourself. It IS a high alkali product, not an acid. (Alkali & acid will nullify each other--very simply put)
Yea, I know, but there is an ingredient in there that is hard on glass. Trying to remember basic chemistry, I beleive it has to be a hydrofluoric compound to etch glass if I remember correctly. I'm sure somebody has the MSDS sheet that will explain that. There isn't any warning on the bottle but my uncle told me the factory told him about the glass pitting.
There, clear as mud.
Good stuff. Kind of like souped-up Fantastic. Great for taking spots out of clothes - my MIL and wife swear by it. Good for all around cleaning too.
Any alkali worth its salt will etch glass.
An alkali is a base (as opposed to acid), is caustic and has a high pH. If it was acidic and had some hydrofluoric mixed in, it would rapidly etch glass.
I have used it and loved it however in my experience it seemed to deteriorate the threads that bind vinyl upholstery together. This seemed to repeat itself wherever I went with the product, o I stopped using it. Could this be for real, or just my own bad luck?
