Originally posted by jmeirhofer
I have a leaking Norcott seal on one side and a drip while running from the prop shaft trans seal on the other side. So I a pulling the shafts and replacing both seals on both sides. While I am at it I m going to do the cutlass bearings, tune the props, have the shafts checked and service the rudders. I also plan to strip all of the old bottom paint and start fresh. On the inside I am replacing all of the battery cables and possible replacing one of the alternators with a HO. I am also pulling the heat exchangers, including the genset and having them cleaned out. While I have the genset out of the hole I am putting some sound deadening in there and painting it. There are a few other things I want to get done to but those are the big ones.
