Update - Alpha One lower unit Remove and replace
nph
I need to change the impellor on my 1987 Alpha One Gen1 outdrive.
I will be picking the manual up on my way home tonight, but some real experince advice can never hurt.
I know that the drive has to be in forward when I take the lower unit off and replace it, but once the unit is off, How do I make sure it is in forward before I re assemble it? I am worried that I may knock it out of gear while I am replace the impellor.
I really need to get this one done on the first shot, as I have to do it at the local ramp!!!
scott
If all you are doing is replacing the water pump impeller you don't have to remove the drive from the boat. However, you need to seperate the lower unit from the upper. That process doesn't require putting the drive in forward gear.
eric
The reason for putting it in gear before you drop the lower is so you can turn the wheel a bit by hand to line up the splines when you reassemble...
Put the drive in forward even if you're just dropping the lower half. This puts the shifting rod in the forward position. When putting the drive back on the lower shift rod HAS to be turned clockwise until it won't go anymore. Then put a bungee cord around the prop and drive to hold the prop hard against the counter clockwise stop. This locks the gears in the forward position.
Don't forget the little quad ring(O ring) between the upper and lower case that seals the oil transfer tube.
Charlie,
Thank You!!!
Thats what I was looking for. One other question, once I get it all back together, is there any way I can tell if the shifter is in the right place?
Yup! Forgot to mention, with the shift rod turned clockwise the foot thingy should be pointing forward to line up with the shoe thingy which should be pointing straight forward because the remote shift is in forward gear. Make sense?
Bungee cord, never thought of that. I've always used knees, shins, shoulders, etc....
I did mine last weekend. Did not remove the drive. Left it in neutral. No [problems....took about 25 minutes.
If it still works right, the shifters in the right place...
Make sure you check your gear oil after you've run her around.
OK with the advice I got here and the manual, I was able to change the impellor and water pump housing with out any problems.
But the job is still not done! I removed the lower unit, replaced everything, and replaced the lower unit. Then I went to remove the vent plug, so I could add the gear oil, but it would not bundge. I broke 3 screw drivers trying to get it out. I had to call it a day and put the boat back in the water the way it was.
I was on a public ramp, no over night parking, a bridge I cqan not trailer under and a borrowed trailer. The boat has twins, so I motored back to my dock on one screw.
Next week I plan to try again, but what was usggested to be, was to remove the cap on the upper half of the stren drive, and add the oil from there. Then this winter when the boat is on the hard for the season, address the vent and fill plugs.
I have two questions.
First does this sound reasonable?
Second, the bolts on the cap, are more like a torx bit, then any bolt head I have seen, and not like a torx screw, they look just like the bit. I was told I need a 12 point socket to remove them. Does anyone know what size?
Again thanks for all of the advice and help.
Scott
