- Jan 1, 2000
- 3238
- 4,831
In amateur radio, the rule is "use the minimum power required to establish and continue communication". I have not checked but that should be a rule for all other transmitters as well.
This courtesy/rule, when followed, reduces background interference for all involved.
Which brings up the question:
Do you ever/sometimes/always adjust power on your VHF to suit the intended communication?
Do you use 25W to chat across the harbor? Do you reduce it to talk to you fishing friends a little less publicly about the hot spot?
