Warning Beeper Going Off
help
My 2002 SeaDoo 18" Utopia with a 200 HP Merc inboard Jet Drive sounds a warning beeper at about 1500 RPM. The warning beeper will then continue going off about every 2 MIN.
It beeps 4 times at these 2 min. cycles.
Any thoughts on what to look for and what I can do to fix this problem?
Does someone have the book Bill mentions that can tell us what the 4 beeps mean and what to do to fix it?
Thank you very much,
Help
Other than suggesting that you check the engine manual for the beep code, no, sorry, no ideas...
Good luck!
From the Mercury website:
"Do I have to use a SmartCraft Monitor with my OptiMax engine?
No, however the operator will be at a disadvantage without a display, the only warning information available will be the horn, and the operator may not be able to identify what caused the warning system to activate. An overview of the warning system follows:
The SmartCraft warning system incorporates the display screen, the warning horn and the Guardian Protection system. The warning horn is located inside the remote control or is part of the ignition key switch wiring harness.
Alarms Warnings - When a problem is detected, the warning horn sounds and the name of the offending alarm appears on the display.
* If problem can cause immediate engine damage - the horn will sound continuously and the Engine Guardian System will respond to the problem by limiting engine power. Immediately reduce throttle speed to idle and refer to the warning messages on the monitor and descriptions in the Operation, Maintenance and Warranty Manual to tell you what to do about it.
* If problem will not cause immediate engine damage - The horn will sound but not continuously.
Refer to the warning messages on the monitor and descriptions in the Operation, Maintenance and Warranty Manual to tell you what to do about it. Use the Bookshelf link on the Dockstore page if you need to place an order for a replacement manual.
Engine Guardian System - Monitors the critical sensors on the engine for any early indications of problems. The system will respond to a problem by reducing engine power in order to maintain a safe operating condition. The monitor display screen will show the percent of power available. "
If you do not have smartcraft gauges, my only suggestion is to find a mechanic with the laptop and software to read your particular engine computer.
Bill,
Thanks for taking the time to reply.
For five years it has been a great boat. I hope someone can come up with a fix for this problem.
Sandy
As far as I know, ( I had Optimax's without the Smartcraft stuff ) there are only two ways to deal with the issue:
a) get a mech to tell you what the computer says
b) start replacing stuff till it works right.
(a) is cheaper. ( Not by much, however ).
Good luck!
I found a mech. that knew what was wrong. There are two reasons for the beeper going off four times every two min.
1. Low oil.
2. Water in the gas/water filter.
My problem was low oil. Even though I filled the large oil tank I did not fill the small tank attached to the side of the eng. which needed filling because I had let the large tank go down too far.
I want to thank you for your help and I hope this information might help others.
Thank you.
