Hello.  I posted the following in the general forum but was told this might be the better place to post.
Well, my surveyor looked at the 1991 Silverton 34' X I was intending to buy. My request was to do the inspection in two phases, with the first being an out of water inspection of the hull.
He came back saying the hull it self is very solid and no sign of moisture in the fiberglass itself.
However, every stringer in the boat pinned his meter so he has no dry stringer to hammer on to determine what it should sound like to determine structural integrity.
So I called Silverton and they said the plywood inside the stringers is strictly for the form and not for structural integrity with the exception of the stringers the engine is bolted to. He said if the wood in the stringers for the engine brackets is bad, there would be play or movement in the brackets for the engine.
So, what am I to believe? Have other Silverton owners had this issue before? Do I believe what Silverton says that the wood is not for structural purposes? If I turn this deal down, do I find that any other Silverton boat of this vintage is going to have the same problem?
Help and opinions on this issue are appreciated.
--Rick
--Rick
