Is there any existing core material in this part of the transom? How thick is the transom where the hole is? I would sand 6" around the hole, tapering the sanded area from the gelcoat and sanding deeper as you approach the hole. do this on both sides of the hole. If there is existing wood core material or the transom is very thick, I would make a plug from marine plywood. Bond it in with a paste mix of epoxy resin and milled fibers. let it cure a couple of days as epoxy resin can take up to 7 days to fully cure. I would then sand the plywood, coat with epoxy resin on both sides and layup several plys of fiberglass cloth on both sides. make each subsequent ply larger so it tapers outward. When cured, sand very smooth and blend into surrounding transom. You may have to fill with a glazing resin to get a very smooth surface. Spray with matching gelcoat on the outside,but if the inside area is gelcoated, I would spray inside as well. Wet sand and compound the gelcoat to a shine, then paint if its bottom painted. Why gelcoat if its paintd? Gelcoat is a water barrier as well as for looks. A 1" hole is significant. This is not just a screw hole you're filling. No offense, but I would never use 5200 on a repair like this. one part adhesive/sealants like 5200 are nowhere as strong as 2 part epoxies. You also need woven fiberglass reinforcement to plug a hole this size. If this repair were to fail while at sea, you could sink. Ask a couple of professionals how much and how they would plug this hole and compare to all other opinions.
