Hi all,
Our trailer is a 1986 Load Rite with 24 black wobble rollers supporting a 1987 Chap 198XL.
A bunch of the rollers are showing cracking under load so I figured it's time to start replacing them. I was thinking I'd just do them all in a non marking poly type but it might not be so easy.
They're 4-3/4" diameter, 3-1/2" width, 1-1/8" shaft, 1-1/4" bearing length. They are ribbed. Found them on an East Marine site in black (OEM) but not having much luck elsewhere. Now I know the shaft and bearing length is critical, but I'm seeing a lot of 5"D and 3"W rollers. I'd be fine with a larger diameter but I don't think I want less width. I've checked amazon.com, boatfix.com and iboats.com and ebay.com and no luck. Any ideas? Or should I just suck it up and replace only the ones if need of it with black and deal with the marks?
