Hi,
I am having a problem with my tilt trim function on my 1993 Wellcraft 232 eclipse Volvo penta 570 Dula prop outdrive. The boat has one of those single handle mporse shifters that also has the tilt and trim controls up on the handle. There are 5 wires that go up to the 2 switches on the handle. I only get down function but no up function. When I press either one of the up buttons I hear a relay clicking behind the dash but the motor does not run. This boat also has a tilt trim module #857534 behind the dash. So it has 2 relays mounted on the motor plus the 2 relays behind the dash. The problem started when I noticed the white and blue wire that go to the shift control; got frayed and shorted out around the handle and since I fixed those wires I now have this problem with no trim up. I do not know if there may be a fuse or breaker or something I should look at or where can I start to troubleshoot this problem?
Ed
Ed
