Originally posted by KiDa
The static line is about 13" (maybe a tad more) above the water line at max load. That is full fuel, full water and a bunch of people. If you can max the weight great, if not four or five people should be enough.
Take [EDIT ADD] a yardstick or similar [/EDIT] and tape it to the top of the outboard riser with one end touching the hullside. Ballpark where that is from a reference point in on the hull. That could be X inches over a thruhull or Y inches from the hull deck joint...etc... Whatever works for you. With all that weight on board, measure the distance from the water line to the where the ruler is hitting the hull. If that is greater than 13" you are OK. If you are at 13" or slightly below, you are still at risk but marginally as you may not travel with all that weight as the norm.
The fix is a spacer in the manifold and the riser. I think BF hasa them.
I don't recall the problem having to due with the tube exhaust, but I could be wrong. Wouldn't be the first time.
