Looking at 34 Searays 1999-2000, in addition to some other boats. One has 380 Horizons, the rest have the standard 7.4's. Anything I should look for besides the cramped engine room?
Do lots of research on the web about water reversion. Not ingestion. I believe the 7.4s in that year range had the most trouble. My 88's in a 340 sundancer has gone thru 3 engines. I think I may finally have it solved. If it is reversion simply checking and changing exhaust manifolds/risers is not enough. It is a poor engine design for the application. So far everything I have read is that the Searays are the worst for this issue. All the stories seem to be only with the V drives so if your talking engines forward in the salon you may be OK.
Become an expert on the reversion issue before you buy. I added resonators in the exhaust which are apparently helpful although I understand they may no longer be available. I have also learned to never idle below 1500 which means shutting one engine down for 5 mph zones. If the engines ever come out again I will consider a cam regrind without the valve overlap.
