4 blade prop question
lrdchaos
This is my first post, I have a 06 tahoe q7 with a 5.0mpi and bravo 1 sterndrive. I had a 3 blade 19pitch vngence, with that prop I would reach 5150 rpms. I just put a new solas 4 blade 19 pitch prop on, now I can only reach 44oo rpms, but my speed only reduced by 6 mph. I replaced the prop due to wanting more holeshot for skiers. Any help on why the rpm drop was so dramatic would be helpful. Also I don't feel the hole shot was that much more if any.
Four blade props are generally consider more efficient and to achieve the same rpm would use lower pitch. Most dealers will exchange them if toy are not happy.
I was under the impression that a four blade would only drop the rpm 150-200 rpm, would it be 700+ rpm difference?
There is less slip and a significantly larger DAR or diameter area ratio with the four blade and I am not surprised at the RPM drop. A typical 3 blade will fill .65 of a circle with blade while a typical 4 blade will fill .85 That is a lot of extra water to push and will really load your engine if you do not drop pitch. The 4 blade may also be cupped for more rpm loss.
You need to drop at least 2 inches of pitch to offset the extra blade.
Thanks, I just called my prop guy and that is what he recommended. I have a 17 pitch on order. Thanks for all the help guys.
