6 pack license
simplebrad
How do they "verify" sea time when you apply for the 6 pack license. Do you have to log sea tiem somehow through the Coast Guard?
no, honor system with the threat of penalties if you cheat and get caught.
if you own the boat on which you are claiming sea time, you sign the form and attach a copy of the doc./reg.
Otherwise, the captain or the owner signs the form.
Exactly like Pascal said, it's all on the honor system. I passed the test in May and I am trying to document all my sea time now to submit all the forms to the Coasties. You need 360 days since you turned 16 (4 hours= 1 day).
Anyone have any tips to make the documentation process a little less painful?
-Bob
We were just talking about this over the weekend. How does it work with regard to size of boat and body of water etc. For instance our prior boat was a 20' runabout on the Baltic Sea which I put over 200 hours on in 2 seasons. We have moved back to the US and moved up to a 36' boat which I put roughly 70 hours on this summer. Would my time in the other boat count or would I just count the days on the 36'?
For OUPV you can use whatever time you have operating any size vessel. On the Sea Time form it will ask you for information for both the boat and the body of water where you operated it, lake, river, ICW off shore, whatever, length of vessel, HIN, Registration number, etc. and by date. So, unless you keep a log book you will have to work from memory. As Pascal said, it is pretty much honor system.
You will need to fill a separate form for each different vessel you operated. If you owned it you will have to provide proof of ownership. If the vessel was owned by someone else you will have to show such ownership and get the owner to sign the Sea Time Form. The type of "Sea Time" you have may restrick where your license allows you to operate. i.e. Lakes & Rivers, Inland, Near Coastal, etc.
Any further information you need is easily found on the USCG web site.
Time in the 20' boat will count toward your license, but may limit the tonnage if you apply for a Master's License. If all of your time is in vessels of 5 Tons or less, your license would be limited to 25 tons. The time in your 36' boat should bump the license up to 50 tons.
Scott (Boydski) Boyd
Bob, I created a simple spreadsheet to capture the days by month. I put years across the top. I used a column for each boat. In most years I operated more than one boat so I tracked them separately.
Then I put the months into a column. This allowed me to total days per month for each year.
It's a simple spreadsheet, if you like I'd be happy to send it to you.
Terry
Thanks Terry, that would be great! I think I have my time documented OK, maybe I'm just thrown a little by picking random dates and times over he years. I'm documenting 2 vessels, my boat and my buddy's 40' Formula that he has had me skipper for him over the years. Also, did you run into any issues when you submitted the forms to the CG? I had a guy in my class do nothing but bash them for problems he had submitting his paperwork, don't know whether the problems were caused by him or not.
-Bob
-Bob
Keep copies of everything you submit! They WILL lose something along the way.
A few little tips for the future.....
Your license is good for five years. If you are actively using your license, then you should submit your renewal package 4-6 months prior to the 5 year date so as to avoid any lapse. If you do not 'need' the license you have a one year grace period from the 5 year anniversary date to submit your package for renewal. I was told as long as they receive your renewal package before the one year grace period expires that you are OK.
You don't need to get fingerprinted for renewal....you just need your TWIC card. However, you MUST confirm with the TWIC personnel that you checked off that your occupation is Mariner so that they send off your records to the USCG. ALL applications are sent to West Virginia for processing.
Your renewal package should include:
-Form CG-719B(Rev 03/04)-F5 'Renewal Application Form'
-Form CG-719K (Rev 03/04) 'Merchant Marinaer Physical Examination Report
-Form CG-719P (Rev 03/04) DOT/USG Periodic Drug Testing Form
-Form CG-719S Rev (03/04) Small Vessel Sea Service Forms and proof of ownership of the vessels used. Keep all registrations, insurance cards and/or USCG documentation certificates from every vessel from every year. You will need them again to prove ownership of the vessel you are using for your sea time.
-Copies of the front and rear of your TWIC card
-Copies of the front and rear of you curent Marine Officer License
-Check for $95 made out the USCG
All forms are downloadable from the USCG website.
If you don't meet the sea time criteria you can test out.
If you are employed in the Marine industry you can substitute an approved letter as a participatnt in an approved Random drug tesing program. But, it must be from the Marine industry. CDL license participation is not acceptable.
Keep copies of EVERYTHING you are sending the USCG now....you can use them for reference in 5/6 years.
The USCG promises to have the entire renewal process online in a year or so....we'll see!
Bob, Only issue I had was that I either forgot to include or they lost my CPR certificate. CG sent me a letter telling me the CPR certificate wasn't included. I called the number on the letter, asked the person who answered if she could tell me the reviewers name and a fax number. She was very helpful. I faxed the info to them and a week later my license showed up in the mail. Seemed easy and painless to me.
It took 5 months but I've been told it can run from 9 to 20 weeks.
Terry
it's pretty easy altogether, just make sure you fill out everything and submit all the required paperwork
the key thing to remember is that a day must be 4 hours under way; if you run for an hour, anchor out, and come back, you cannot count that day.
minor detail but you dont' have to keep reg/doc for every year you own a boat. just one over the ownership period is enough.
.....minor detail but you dont' have to keep reg/doc for every year you own a boat. just one over the ownership period is enough.
It may depend on the reviewer, but I personally had to make a special trip to the NJ MVC to retrieve old registration documentation.
For example, having a registration or documentation cerficate from 2007 doesn't prove you had the boat for 2004, 2005, 2006 and 2007 seasons...the years you may be claiming the sea time on that vessel. At least that was my personal experience. I will never throw away another doc/reg/insurance card again. I also just went through the same beaurocratic crap trading in my 'clunker'....
may be a local thing... nothing is proven anyway, if anything if the USCG smells a rat the one thing they can pull is actual doc. data to see what year you own the boat.
It's not local....all applications are proceessed and reviewed in West Virginia. If the boat you are using for the sea trial is not a USCG documented vessel, just registered locally, the USCG can't pull the neccessary docs.
would our time in an offshore 50 foot race boat count? or does owning a 100 ton tug count or does just the time we run it? i,m on the water almost every day and drive hundreds of boats a year sometimes several in a day do they all count?
Thanks for the heads up guys. I think I'm going to run into a problem with the copy of my drivers license. I've moved and didn't have tjime to get to DMV to have it changed before I took my 6Pack class. I had to hand in a copy of it there.
Also, as far as the 4 hours underway goes... I can't remember my hours from early this spring let along 10 years ago. I'm pretty much making it up as I go along trying to be as accurate as I can.
Kevin
any time on any vessel, even a 9 foot dink counts... sail, power, doesn' matter. Teh keys are
- prove you owned the boat (reg/doc) or have the owner / captain of the vessel sign the form
- for a day to count, you must have been underway for four hours. Drifting is considered underway, but not being anchored
- time on board counts, regardless of position. A deckhand can count the days even if he was no operating the boat
Yeah, and for those who are reading this and chuckling to themselves while simultaneously signing up for a captains course. Your chances of getting busted in the licenseing process for exagerating your experiene is low. Captains courses teach you how to pass a test, not how to be a mariner. However, if you don't have the sea time and actually do get in the middle of servicing passengers, your chances of somebody getting hurt along the way are not minor. Notice I did not say your chances of hurting somebody, I said the chances of somebody getting hurt. You are responsible either way.
If you want to see a true colonoscopy exam, just wait until the CG starts an investigation into an incident. Unfortunately, the time when you are most likely to get busted for exagerating sea time is exactly the cirumstance you don't want to be in the middle of.
I can smell a 6 pack cheat from sight alone. Imagine what somebody who does this for living can do. These things have been handed out like candy the past few years. Lots of guys have them that will never be able to pass their renewal sea time requirements as that is not based on forever the second time around and we have not yet seen the fallout of the masses of unqualified folks getting through. Were still waiting for the teachable disaster to occur that will drive a change, and likely prosecution to go with it.
I'd really think twice about exagerating. While there are lots of folks not minding the store allowing all this to happen, its still you who is signing on the bottom line attesting to thinkgs you have not really done. The fact that a clerk went ahead and accepted your statements as true won't mean a hill of beans when it counts. Your going to get prosecuted either way while simultaneously opening up the floodgates to civil lawsuits for which your insurance will walk away from.
