- Apr 4, 2009
- 31163
- 2,834
Dismanteled my A/C cooling water system yesterday for its annual spring cleaning. The tubing I am using is the nylon reinforced transparent plactic tubing and the inside of it looks really crudded up, almost black in many places.
So, my thought process is that if I have that much build up in the tubing the cooling coil has to be just as crudded. I am replacing all of the tubing but how do I clean out the cooling coil on the A/C unit?
Suggestions please.
I used a solution of CLR,Clorox and water run through the system using a small bilge pump and a 5 gallon bucket. I ran it for a couple of minutes until the system was full of the solution, stopped it and let it set for one hour then ran the rest of the solution through it. I then ran a bucket full of fresh water to remove all of the CLR and bleach.
I also have one of those syphon gizmos that keeps the condensation pan dry. It was fairly dirty so I removed it and cleaned it out really good and put it back in place.
Problem solved. Runs good, good water flow and the tubing looks so good I didn't have to replace it.
Suggestions please.
