- Jan 20, 2002
- 7269
- 802
I replaced my POS Cal pump with a March pump. The Cal pump was 580 GPH and the March pump is only 510 gph. I had called March tech support to ask them about the flow rate and they assured me that the flow rate was good for servicing up to 24,000 BTU's. I have a 12K and a 6K unit. When I first started up the system, the 12K unit shut down after about 15 mins. of run time. I hooked up city water to the water line feeding the units and blew out a lot of dirt and sediment from what I assume were laying in the coils. After hooking the units back up to the pump, everything seems to be working properly, but I was curious about the existing water temp. and it felt very warm-a rough guess would be 110-115 degrees! I never checked the water temp previously, but this seems pretty hot. Does anyone have an idea of what the water temp coming off the A/C should be? The raw water temp now hovers around 90 degrees.
