Abaltive Paint???
Moderator
What's a decent but cheap paint to use? I use to have the yard put my paint on, not sure what brand it was, but I assume it was cheap stuff. I paint the boat every year, so longevity is not a problem.
With the cheap paint they use, I have had virtually now growth on the bottom of the boat. Keep in mind I am from the North East, boats only in the water for 6 or 7 months and I use my boat.
I use International Paints XXX. Nasty stuff to apply, respirator recommended. I don't like the way it messes up the boat above the waterline. It's very soft but works as advertised. I think it's one of the cheapest options for antifouling.
I have used the Interlux Micron Extra w/ biolux. $230 per gallon but it is a multi year ablative. So I just touch up every year. The new boat will use Petit products becuase that is what Regal uses. You really need to know what is on the boat becuase you can only apply certain paints over certain paints. Interlux has a good website as does petit.
Interlux's site:
http://www.yachtpaint.com/usa/default.asp
Walt I don't think it matters much what kind of paint you use as opposed to how much you use the boat and how the bottom is prepped for paint. If you use the boat the stuff gets knocked off. Let the boat sit and it grows. We using micron csc (ablative) and I think last time it was the 'extra' version. In fresh water up north we never had an issue. Down here if we sit for a month we have all sorts of dingleberry stuff hanging off everything under the waterline. If I run it up to 15 knots for an hour most of it is gone.
All we do is pressure wash, sand a couple of spots and re-apply a coat over the bald spots and then do the whole bottom every other year. We touch up the water line every year. But now we are in salt and it's totally different. So a re-coat once a year is probably in the plan. That and 1700 nautical under the keel probably will dictate a fresh coat.
Interlux Act Alblative has worked great for me for 8 years in the Long Island Sound, less than $150/gal if you shop around. Once a year. I couldn't find it on Boatfix.
CurrentSea, How can you tell what is on a boat already? The boat was already painted when we bought it last year. I do know it rubs off to the touch and the surveyor couldn’t use his moisture meter on it. I recall he said the paint had metal in it. I do need to do some touch up this spring and I’m not sure what to put on.
Niles
They say if you don't know what is on the boat then sand it off.
That is what I did when I got my boat.
I sanded it.
Wiped it down with thinner.
Applied 1 coat of orange micron.
Applied 1 coat of black micron.
At the end of the season whereever I see orange, I touch up with black.
I was a afraid that would be one of the answers:) Too many other projects to get done in our short work window this year. Hopefully it can be figured out.
Niles
An excellent paint made by the same manufacture of the "name" brand paints. $100 a gallon.
http://www.boatfix.com/shop3/store/viewItem.asp?idProduct=17989
Also available in blue & red.
According to interlux's website, epoxycop is a hard paint, not an ablative.
That label looks odd too.
Not the label on the website.
That paint is a single season paint. Any deals on a multi-season paint out there?
Dave, sorry but you are 100% wrong on this. The epoxycop is available in BOTH hard and ablative. I've been using it for years.
I get a minimum of 2 years out of it and I keep the boat in the water year round. I do use 2 coats thou.
Its odd cause that is not what Interlux says on their website, but I see that on the can of paint.
It is a cheap ablative.
I got 5 years out of my multi season ablative with touch-ups.
So at $230 a gallon the first year (one coat), then 1 gallon every 2 years for touch ups.
I think if you do the math its about the same.
I will see how Walter makes out with the Epoxycop.
He is in Salt and you are in Fresh.
We get a lot of slime down here which the biolux prevents.
Though if you use the boat its not a big issue.
For me its more that I don't want a buildup of paint on my boat.
Fresh water? Hmmmm.... Better tell that to the crabs. Time for them to move on!
Yes I get your point, but the Hudson is not considered fresh water in the area that I boat. Due to tidal flows there is a fresh/salt line which moves up and down and it's north of where I boat. Here's an older report if your interested, http://ny.water.usgs.gov/projects/dialer_plots/Salt_Report-0803.pdf Basically shows the salt line approximately 65 miles up river from the battery although it can be even farther. Where I boat is roughly 35 miles up from the battery. Just an interesting tidbit...
its worth noting that some paints may have a bond failure when applied over another different type of paint. it is best to stick with the same product if you don't plan to take it all off as part of the prep work. as others have noted the location of the boat has more to do with the effectiveness of the paint. down here i've found that the SR additives make a significant difference. i also have a diver every 6 weeks to clean the bottom so as i get towards the end of life of the bottom paint the bottom really needs cleaning to run with good fuel economy.
