AC Drainage Question
fountain27
My ac drip pan drains directely into the center bigle. I really hate having any water in my bilges (smell, etc). If I splice the discharge hose with a T and connect the drip pan drain hose all water would be discharged overboard.
Question...I realize the constant running water past the T will create suction, however will this cause problems? Whistling, Pump issues etc?
Thanks.
If I'm understanding what you're asking, YES, this will cause problems, but not what you're thinking. You will be pumping your discharge into your condensate pan. You can't simply put a "T" in line or it's just another route for the pressurized water (discharge) to take - picture a "T" in your normal plumbing. Constant water running past a "T" will not cause suction. You need to form a pressure drop by using a venturi device. I can't remember the name of the company - maybe someone else knows - but there is a company that makes just such a device to suck the condensate out of the pan. They aren't exactly cheap, though.
Most boats have the AC discharge draining into the shower sump pump where it gets pumped overboard
A basic problem with the AC drain is that the unit is often mounted fairly low in the boat. Since the drip pan is underneath it often ends up below the water line. If you tapped into a thru hull you could end up with water flowing in instead of out. It would be a really bad idea to have a thru hull drain that wasn't terminated at least a foot above the normal water line.
Does your boat have a shower? I bet the shower drains into a sump pan that has a pump to discharge it overboard. You might try routing your AC drip pan to the shower sump and let it pump it overboard.
Rod
yep... dont do it.. unless you want to sink your boat :-)
either route the drain to your shower sump, install another sump if the shower is too far, or use the device that sucks condensate into the sea water flow (dont remember the brand). although personally i dont' like the idea of some kind of valve preventing sea water from back flowing...
mmair.com
"Condensation Removal Device
The Mermaid Condensator is the solution to water in your bilge! For anyone looking to prevent condensation from reaching the bilge or the sump pumps, Mermaid has your solution!
Working the the "Venturi" principle, the Mermaid Condensator is installed in-line with the marine air conditioners water discharge line. As the marine air conditioner and sea water pump are running, the device creates a vacuum effect and literally pulls the condensation water out of the drain pan, merges it with the discharge water, and you condensation is now overboard! The principle here is to leave your boat a "dry boat" by removing all condensation from the marine air conditioners drain pan, bilge, and/or sump pump."
Thanks. Makes perfect sense. I could just visualize the impending disaster.
I may try to route the house to the shower sump. Great suggestion.
I installed a Mermaid Condensator on my A/C about three weeks ago and couldn't be happier with the product.....and the dry bilge. My situation was a little different than yours though. For whatever reason, some engineering genius at Carver made our a/c drain UPHILL to the shower sump (I'm not kidding) and basically destroyed the old a/c unit because the compartment where the a/c is located would collect standing water, thus rusting out all kinds of stuff. Anyway, I eliminated that problem and it only took about ten minutes to install the Mermaid Condensator.
I have been using the Mermaid Condensator's on both my AC units since the begining of the summer since I replaced my old AC units, greatest device since sliced bread! In other words they work great and make no noticable noise. Regards Bill
It's my 2nd season with the condensator. I believe my condensate pan is dryer with that than if it just drained into a sump. No noise at all.
I also installed the Mermaid condensator and it works great. The original configuration had the A/C draining into the bilge because there was no way to drain it to the sump pump without a slight uphill run, which would prevent good drainage. I left the hose that drains to the bilge attached as a backup and installed the condensator drain hose in the corner of the pan. Never get a drop of water in the bilge though. You can get the condensator for 150.00 from Yachtmd.com.
Another reason to route condensate to a sump is fresh water. Fresh water in a bilge promotes rot if stringers are not fully incapsulated with glass and resin.
I installed a Mermaid condensator in my boat too. I originally installed my condensate drain into my shower sump.
