The real question should be: Why did it not work?
Sounds like you had two issues:
1) Since it "did not work at all during the day" I would conclude that the unit was too small ( ie: 5,000 BTU vs 10k or 15k )
2) the second problem: "too cold for anybody in the aft cabin and hot up front at night" means that you did not get proper circulation, which might also involve problem (1).
My though would be to get a marine unit, that has "installable ductwork" to solve the circulation issue, and then get a unit that has more cooling capacity than the one you used.
As a WAG I would guess that 10k to 12k btus would be about right, but I would contact the mfgr of the A/C for proper sizing of the unit ( they may have a do-it-yourself calculator on their website.
A carry-on, without ductwork to improve the circulation will likely not be an improvement. ( You could try using a fan to add the required circulation, perhaps )
A properly sized A/C ( marine or non-marine ), with proper circulation, will work just fine. But you need to solve both issues.
